i can hear clearly now... the noise is gone - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-03-2003, 02:33 AM   #1 (permalink)
rayray's Avatar
View rayray's Photo Gallery
thought I'd treat myself to a b-day gift. i've been eyeing this item on e-bay for a long time now. came across a a brand new one for a good deal at a local audio shop. took it as a sign to buy it.
Clarion DPH910 EQ/DSP/Crossover.
I'll post my reviews once I get it installed. just realized that i've had my amps wired to my subs wrong. had the amps running too hot. good time to change it all up.
-rayray
rayray is offline   Reply With Quote
Old 10-03-2003, 08:34 AM   #2 (permalink)
not actual size
brink's Avatar
View brink's Photo Gallery
Mmmmm.... claaarion
-- Jonathan W.
http://fleshy.org.nz/
brink is offline   Reply With Quote
Old 10-03-2003, 05:35 PM   #3 (permalink)
I get angry when Im sober
Stealth's Avatar
View Stealth's Photo Gallery
I <3 Clarion too
how much the DSP run you for?
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
Stealth is offline   Reply With Quote
Old 10-03-2003, 06:05 PM   #4 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
View Phi's Photo Gallery
Purdy.
How much flexability will that thing give ya?
TN Map - Add Yourself
Phi is offline   Reply With Quote
Old 10-04-2003, 12:13 AM   #5 (permalink)
rayray's Avatar
too much for me to fiddle with. here's a description...
Clarion DPH910 Digital Graphic EQ/DSP
You get a full subwoofer crossover a 3-band front and rear independent parametric equalizer, a 7-band digital graphic equalizer, and a test tone generator.Your system can be tuned from the drivers seat, instead of climbing into the trunk to make a change to the EQ or crossover.
this one will keep me busy for awhile. now i just need to find a place to mount it.... hmmm.
-rayray
Old 10-04-2003, 01:52 AM   #6 (permalink)
Stealth's Avatar
they run for about $50 on ebay... i just might get one, well that is if it works with my headunit. How/where do I find out?
Old 10-04-2003, 01:15 PM   #7 (permalink)
rayray's Avatar
it will work with yours. you have a CeNet unit as well... shown by the "Z" in your headunit's name.
http://www.teamclarion.com/SharedWeb...rt.nsf/edl/F16
DXZ835MP specs
http://www.clarion.com/sourceunit/srcunit02.htm#
this is how you hook it up:
-rayray
Old 10-06-2003, 02:00 AM   #8 (permalink)
rayray's Avatar
hooked up the crossover today. the sound quality has greatly improved. there are several different sound stages to choose from and subwoofer control settings. best part is that i can contol it all from the deck. the CeNet cord that it came with was not long enough to reach the trunk so I just have it setup on my back seat until i can get a longer cord.
-rayray
Old 10-06-2003, 01:24 PM   #9 (permalink)
Stealth's Avatar
I wonder if it's really going to be worth it for me since I'm just going to have 6.5" components in the front? I know I can change the timing a little, but does it matter for 2 speakers? And the crossover, my amps will have built in ones. If my system was for SQ I'd certainly get one of these bad boys.
Old 10-06-2003, 07:55 PM   #10 (permalink)
rayray's Avatar
you'll still notice the difference. my amps have built in crossovers as well but they don't do the job as well. i was surprised how much of a difference it made.
-rayray
Old 10-06-2003, 11:48 PM   #11 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
does this thing increase signal strength too? ie. 4V --> 7V ?
Old 10-07-2003, 12:27 AM   #12 (permalink)
rayray's Avatar
i don't think so. here's the user's manual.
http://www.shopdome.com/clarion2/archives/dph910.pdf
-rayray
Old 10-07-2003, 12:51 AM   #13 (permalink)
Stealth's Avatar
I guess you can't go wrong for $50. I'm pretty sure it doesn't raise the voltage of the signal. It will let you set the timing, volume per channel/speaker and crossovers I think.
Old 10-08-2003, 03:22 PM   #14 (permalink)
View RYANMKII's Photo Gallery
ray, think of running both subs on one channel, bridge your amp
into 2 or 1. run your subs in series, and your subs should thump
pretty good plus your new cross-over. question... brembo brakes,
on the buy and sell, is that legit? by the way... wicked web page!!
RYANMKII is offline   Reply With Quote
Old 10-09-2003, 12:24 AM   #15 (permalink)
rayray's Avatar
i had my subs wired with each voice coil in parallel until just recently running my amp at 2ohms... way to hot for my amps. they kept crapping out due to the heat. that plus being under my plexi with no fans made them unhappy gadgets. but i just wired each voicecoil in series and the subs themselves in parallel. they're runnnin more efficiently, safer and better sounding than before.
i thought you saw my site before?! i got some lights in the trunk that i don't think you've seen yet. i'll have to take some more pics.
-rayray
