Originally posted by RedruM
okay i got RCA's running throught the middle of the car
power on driverside
speaker on passenger side
battery in trunk and grounded all three amps to the battery directly cause there was no real good grounding point in this trunk....
is this how you had it originally or what you did to solve the whine?
your ground wire should be as short as possible. no more than 3 feet at the most. from what i read, your amps are in the trunk... then you're running your ground wire all the way back to the engine bay?
-rayray
