4 Ohms Or 2 Ohms ???? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-31-2008, 06:41 PM   #1 (permalink)
View Cambo98's Photo Gallery
4th Generation 4 Ohms Or 2 Ohms ????
i had some woofer and they are no longer in stock i own 2 ohms cvrs but they only have 4 ohm left what is the difference between the two. i kno the rms is gonna be different but will that change the sound or hard it hit. what the pros and con between the two
Cambo98 is offline   Reply With Quote
Old 02-01-2008, 08:11 PM   #2 (permalink)
Simpsons fan since 89'
Curry's Avatar
View Curry's Photo Gallery
Wow... ok well...
We need more info on the amp(s) you're running and the sub(s) you're running... We need names and models numbers or at least post the specs. We need info on the boxes your using. We need info on your headunit. We need all the info you can possibly give us on your system. I dont even know how asking us if 2 ohms or 4 ohms is gonna help you. There are no pros and cons between 2 and 4 ohms....
Please also take just a little time to read http://bcae1.com
Curry is offline   Reply With Quote
Old 02-05-2008, 06:25 PM   #3 (permalink)
i just wanted to know the difference between 2 ohm and 4 ohm subs that all
Old 02-05-2008, 09:19 PM   #4 (permalink)
touringcamry's Avatar
Gameroom cash: $510625
The difference is the resistance of the coil. Use only what the amp is stable to. If the amp is not 2 ohm stable, the amp will overheat.
2007 Camry 2.4L 5M
Old 02-06-2008, 09:01 AM   #5 (permalink)
View thoughthard's Photo Gallery
If CVR is Kicker, you can contact them about their Trade-In program, if they still do it.
I have done it twice in the past. Blow/ruin a sub, get everything arranged with Kicker, send bad sub in, get new sub back with a full Kicker warranty.
They give you a credit for your bad sub, although the amount is small. Their new price is not a bargain, but if you need to match a past model, this is a good way to do it.
Otherwise, good luck digging online to find one, or waiting for one on eBay...
thoughthard is offline   Reply With Quote
