Help?!?! Is it my amp or my speakers - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-10-2003, 12:48 PM   #1 (permalink)
yo i have 3 toyota's
aladdin102's Avatar
View aladdin102's Photo Gallery
Exclamation Help?!?! Is it my amp or my speakers??
Ok so heres the deal
MY system is great and all the sound is clear through the speakers. the bass is hitting tight and hard.
but when i turn up the volume louder soo the music fills up the car so u cant hear anyone talk, the music leaves the speaker and stops for about 5 or 6 seconds but you can still hear the bass i was like wtf?? it does this about every 30 seconds another time when i turn up the system it does the same thing but i can still hear the music really really low in the speakers. and then for the last time it even does this when my bass is all the way off i have a kicker kx600.4 for the speakers it does this funky thing with a CD and radio sooo its not a scratched CD im soo confused
oh yeah btw i checked the wiring from the amp to my rear speakers looks good but havent checked the front speakers and i pulled my deck out and everything is tight in there too
anyone please help me please helpppp im so very confused
aladdin102 is offline   Reply With Quote
Old 10-10-2003, 11:00 PM   #2 (permalink)
Banning is an art.
Silver Streak's Avatar
View Silver Streak's Photo Gallery
Your amp sounds like it's overloading...going into protection mode and then resetting itself automatically. Make sure your gain levels are set correctly, as in they don't need to be at the highest level.....
Silver Streak is offline   Reply With Quote
Old 10-11-2003, 01:06 AM   #3 (permalink)
rayray's Avatar
View rayray's Photo Gallery
^ ditto that
same thing happened to my amps. i had them wired up wrong to my subs making them run too hot. their protection mode kicked in and turned them off until they cooled off... and over and over again. i have since rewired my amps correctly... no more problems. you should check how you have them wired to your subs and fix the problem right away... it's not very healthy for your amps and can cause permanent damage.
-rayray
rayray is offline   Reply With Quote
Old 10-11-2003, 11:47 AM   #4 (permalink)
aladdin102's Avatar
yeah my subs are fine its my amp thats being run to my speakers ok i will give it a try with the amp gain turned down thanx for ur help
edit: all my stuff was looked at after zonicamry and i installed it so all the wiring is correct
Old 10-11-2003, 11:45 PM   #5 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
View Phi's Photo Gallery
As Silver and Rayray suggested, your amp is overheating. If it's not the gain level or improper wiring...check your ground. I had a poor ground once that caused my amp to overheat.
TN Map - Add Yourself
Phi is offline   Reply With Quote
Old 10-14-2003, 07:44 PM   #6 (permalink)
View phatboy555's Photo Gallery
not too hijack the thread or anything...
but i have a gen3.5 camry and i need a place to put the ground...the sticky said something about a bolt to the seats but i don't see anything...so what do you guys suggest, just sand a part of the trunk and stick it there or what
finding a place for the ground is killing me
phatboy555 is offline   Reply With Quote
Old 10-14-2003, 08:17 PM   #7 (permalink)
aladdin102's Avatar
its cool man yeah i have ground underneath my back seat on the left side of the car and i have ground on a bolt in my trunk behind the right tail light i hope this helps give me a shout out on AIM at daveeisner69 i would love to talk camry with ya dude peace
Old 10-21-2003, 05:33 PM   #8 (permalink)
aladdin102's Avatar
anyone else i went to tweeter they are dicks i cna get my amp bench tested for $10 but i know the amp isnt 100% gone because it still makes sound with the volume not turned up all the way and they actually want $45 to know exactly what the problem is and then another $25 to ship it to kicker and have them look at it then they call me to tell me how much it would be to fix it this crap suckssss anyone else help??? everything is fine just that stupid no music when the volume is up
