JL subs. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-09-2008, 06:01 AM   #1 (permalink)
keepin' it real.
rea1ist's Avatar
View rea1ist's Photo Gallery
JL subs.
what JL amp would u guys recommend running two 10" JL subs?
i wanna run these-
http://mobile.jlaudio.com/products_s...p?series_id=15
rea1ist is offline   Reply With Quote
Old 03-09-2008, 03:19 PM   #2 (permalink)
View anoiel's Photo Gallery
get the 500/1v2 if you just want a jl amp but i would most likely get a differnet brand amp since i think jl is good but way to overpriced.
anoiel is offline   Reply With Quote
Old 03-09-2008, 07:23 PM   #3 (permalink)
keepin' it real.
rea1ist's Avatar
oh ic what other brands of amps would u recommend running those two subs.?
Old 03-10-2008, 08:59 PM   #4 (permalink)
ks 500.1 by arc audio
Power output RMS @ 4 ohms 1 x 450 watts Power output RMS @ 2 ohms 1 x 600 watts Power output RMS @ 1 ohms 1 x 600 watts Transient Distortion (400W) <.05% @ 4 ohms Frequency Response 20Hz - 250Hz S/N Ratio (A wtg.) >112dB Bass Boost +15dB@10-125Hz Crossover (Butterworth) 30Hz - 250Hz variable 24dB Fuse 30A x 2 Size 13.0"(L) x 8.0"(W) x 2 3/8"(H)
also look at kickers zx500.1 go to kickers website to see stats but really before i suggest more we need to know what kind of budget you are on or i could refer you to the arc audio 2150se which cost about a grand
2 Channels @ 40hms 150 Watts 36A 2 Channels @ 20hms 300 Watts 73A 2 Channels @ 10hms 300 Watts 94A 1 Channels @ 80hms 300 Watts 34A 1 Channels @ 40hms 600 Watts 69A 1 Channels @ 20hms 600 Watts 95A Frequency Response 7 Hz > 50kHz Crossover Range 30Hz - 550Hz (x10 300Hz - 5500Hz) Bass Boost 0 - 15dB @ 20Hz-80Hz S/N Ratio (a wtg) ref 1Wall 40hm >88 dB Seperation @ 1kHz >70 dB Dampeninig (25W 2x40hm 100Hz) >2500 Low Level Imput Sensitivity .3V - 4V Balanced Input Sensitivity .6V - 8V High Level Input NA Max Peak Current 20hm Mono 125A @ 1060Wats 20% THD+N Efficiency at rated 2ohm Stereo 59% Idle Current 1.50A Dimensions 151/2 "(L) X 8"(W) X21/2"(H)
Old 03-11-2008, 12:38 AM   #5 (permalink)
touringcamry's Avatar
Gameroom cash: $510725
2007 Camry 2.4L 5M
