Want XM or Sirius for my 04 Matrix - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-09-2008, 10:14 PM   #1 (permalink)
View tydwbleach's Photo Gallery
USA Want XM or Sirius for my 04 Matrix
I would like a CD player Regular radio, satellite radio for my 2004 Matrix. I love this car the only thing wrong with it is that the light in the radio went out and I 'd rather just get a new one anyway. WHERE do I go for this? I looked in my husband's Crutchfield catalog but I was not sure about compatibility.
Maybe I should try like Cartoys or something? I am near Portland, Oregon. Does the dealer have anything like this? I do not want to do it myself. Maybe get new speakers for the new system too. Is this going to be like a HUGE problem?
If you want to get all technical go ahead my husband makes guitars and I may not understand what you mean but he will Can anyone help or has anyone replaced the factory radio in their Matrix?
Thanks ahead of time. Liz
tydwbleach is offline   Reply With Quote
Old 03-09-2008, 11:03 PM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
You can replace the stereo with one you buy from Crutchfield if you want. If you go to Crutchfield's website, they will tell you what will fit based on the description of your car. There are other places where you can buy the stuff for less, but Crutchfield has excellent service and knowledge - which is reflected in their prices.
You will need a dash kit and a wiring harness will make installation easier but not required. A dash kit is a basically going to be a plastic frame that goes around the stereo to fill in space because aftermarket radios have standard sizes but stock or factory units are often not standardized. Aftermarket radios have bare leads coming out of them and have different colors than the wires in your car. The wiring harness will connect to the bare leads and then mate directly to the connector for the stock radio. If you don't use one, you'd cut the connector for the stock stereo and splice the wires.
For sat radio you will need an external tuner module. Some modules have a display with their own controls and some utilize the display on an aftermarket radio and the radio's controls. For best sound quality, you want one that connects with a wired connection such as some type of line or auxiliary input. You do not want a FM modulator or transmitter type. The FM type plays through the FM radio and in some urban areas can become completely unusable and may be prone to interference.
Speakers can be replaced if you desire. The factory speakers are often ok quality, not bad, not great. For best sound, it's best to use a component set up front rather than coaxial, 2-way, 3-way types. Components are a little bit more work and usually cost more but I think they're worth it. The back just get a good 2-way or 3-way, or consider removing completely if you get a subwoofer.
Do you want an amplifier for the speakers? Radios have internal amplifiers that usually put out about 18-22W RMS per channel but many people prefer to go with external amps that put out upwards of 30W RMS per channel. More power means better clarity at higher volumes. There is more labor to install an amp due to all the required wiring.
Best Buy, Circuit City, and the like are ok, but I prefer not going to them. They don't have much selection and will not order anything for you that they do not normally stock. See if you can find a reputable shop in your area where you can buy the stuff and install it if you don't want to do the install yourself. They are in a better position to do special order stuff for you.
Some brands I like for radios:
Pioneer
Clarion
Alpine
The above companies make amps and speakers too.
For speakers:
Arc Audio
Diamond Audio
Focal
CDT Audio
These companies make mostly speakers and amps. They are less marketed but their lower line products are just as good as competing products from major/heavily marketed brands and audiophile/near audiophile grade items at their high end product offerings.
Do you have a budget? Radios cost between $100 and about $500 depending on features for a CD player. Most of them will play MP3s written to a CD in addition to regular CDs. Speakers will run between $50 and $350 or so for a pair. A really nice set of components adequate for most people will maybe run $200 to $350 but sets costing upwards of $1000 are not unheard of. For the rear speakers, I'd say spend no more than $200 for the pair. The front speakers are more important in my opinion. A satellite radio tuner that will be maybe $50 to $100.
2007 Camry 2.4L 5M
Old 03-10-2008, 10:11 PM   #3 (permalink)
USA WOW THANK YOU SOOOO MUCH for all of the Info!!!!!
I REALLLLY really appreciate it! You seem to know so much I am so glad you answered me!!! THANK YOU!!!! I am excited to get started on this!!!!
