Installed a remote start / alarm on Gen 3 Camry....few simple ?'s - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-16-2008, 07:32 PM   #1 (permalink)
View MineralGray02K's Photo Gallery
The install went well, the remote start works and the keyless entry works. My questions are...
I need to know which are needed for my dome light, door trigger, and engine tach.
Also have any of you ever programmed your alarm to roll down the driverside window? There are a lot of extra cool things that this system can do. Thanks in advance!
1992 Dark Emerald Pearl Camry V6 LE
http://camry.mikefordmustang.com
New York Mustangs - NY Mustang Club
http://www.NewYorkMustangs.com
MineralGray02K is offline   Reply With Quote
Old 03-17-2008, 12:43 PM   #2 (permalink)
Initiated as an Outlaw...
JayMax03's Avatar
View JayMax03's Photo Gallery
I have a Python 871XP installed in my Camry though I don't know what you mean by the question. The dome light tells you when your system is active you might want to restate that question.
1992 Toyota Camry LE ; 4 Cylinder ; Pioneer DEH-P7800MP
Pioneer Premier TS-A641P 4-way 6 1/2 ; Pioneer TS-A6991R 5-way 6x9 ; Cerwin Vega EXL Series 1200D Amp ; Cerwin Vega V-Max 12.2 Dual Subs @ very hot 1 Ohm
Hey! It ain't much to beat the block down, but it'll work for now...
JayMax03 is offline   Reply With Quote
Old 03-17-2008, 12:50 PM   #3 (permalink)
3rd Generation
Thanks for the reply, sorry I wasn't specific. Basically I want the dome light to turn on when I unlock the door. The alarm I have has the capability to do so, but I need to know which wire to tap into. AKA which wire is directly connected to the dome light.
Also where is the engine tach wire? Is it located under the hood somewhere? I need this because if the car is already on and I try to start it, it will not start, and also if the car fails to start, it will measure the RPM's and re-start the car. It will also disable somebody from revving the engine as well.
One more thing I need to know is where the door trigger wire is. This is basically so that the unit knows if / when the doors are closed. If the door is ajar, and the system locks, then when I close the doors they will not unlock with the system.
Thanks!
