Help! Ulra Linear Amps to go with these subs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-17-2008, 01:13 PM   #1 (permalink)
Initiated as an Outlaw...
JayMax03's Avatar
View JayMax03's Photo Gallery
3rd Generation Help! Ulra Linear Amps to go with these subs
Can some1 help me decide which one of these amps would be suitable for (2) Cerwin Vega V-Max 12.2 subs http://www.cerwinvegamobile.com/VMAX12.php. Should I wire them in parallel or in a series. http://www.cerwinvegamobile.com/manu...Sub_Manual.pdf
Amp 1: Ultra Linear UL2402 2400 Watt RMS 2 Channel Stereo Amp Car Audio Amplifier 2402 Bass 2 Ohm Watts http://stores.channeladvisor.com/the...%20Ohm%20Watts
Amp 2: Ultra Linear UL1202 1200 Watt RMS 2 Channel Stereo Amp Car Audio Amplifier 1202 Bass 2 Ohm Watts http://stores.channeladvisor.com/the...%20Ohm%20Watts
I wanted to try my luck with these instead of a mainstream amp and I didn't want anything bridged because I have a 4-channel amp already.
1992 Toyota Camry LE ; 4 Cylinder ; Pioneer DEH-P7800MP
Pioneer Premier TS-A641P 4-way 6 1/2 ; Pioneer TS-A6991R 5-way 6x9 ; Cerwin Vega EXL Series 1200D Amp ; Cerwin Vega V-Max 12.2 Dual Subs @ very hot 1 Ohm
Hey! It ain't much to beat the block down, but it'll work for now...
JayMax03 is offline   Reply With Quote
Old 03-19-2008, 11:55 PM   #2 (permalink)
JayMax03's Avatar
Awwhh Come On Now....
Old 03-20-2008, 12:01 AM   #3 (permalink)
View anoiel's Photo Gallery
i wouldn't believe those numbers i have never heard of them and they might be garbage so if you want to try your luck go ahead but i would buy something more reliable.
anoiel is offline   Reply With Quote
Old 03-25-2008, 01:19 AM   #4 (permalink)
View syang's Photo Gallery
+1
syang is offline   Reply With Quote
Old 03-27-2008, 09:56 PM   #5 (permalink)
View frojoe's Photo Gallery
you have to wonder what they are leaving out to be that cheap...
frojoe is offline   Reply With Quote
