I have a JL Audio 500/1 mono amplifier that isn't working properly. One day the amp started smoking (I think the ground wire came loose and touched the power somehow) and ever since then, the amp will play at normal power sometimes and then half the power at others. Is it worth taking the amp to a repair shop, does it even sound fixable or is it probably dead? Is there a way for me to test the power output using a device of some sort (multimeter perhaps)?
If anyone has any idea what could be wrong with it, it would really help me talk to the repair guys if I do decide to take it in.
Thanks!
I've paid for your sins, now gimme my change!
you can check the power output with a simple multimeter
put it in alternating current mode (AC) and place the probes on the positive and negative terminals of the speaker outputs on the amp and read what they say
[SQ Root of Watts Amp is Rated at] x [Resistance (OHM load) Amp is Rated] = Voltage the DMM Should Read
Start by having the gains down and gradually turn it up and see if you can get the correct voltage to read.
Thanks for the response WhiteRabbit. I got everything you said, except that my amp is rated at 1.5 to 4 ohm stable, and isn't a certain ohm per se. How do I interpret the results at that point?
ohh, i musta misread it cause i coudla swarn you told him to disconnect the driver. But the problem with this measurement is that the driver, when playing, will not hold it's resistance. Say you have a 4Ohm sub, as you start to play it, the resistance seen by the amp will fluctuate usualy from 8 - 2 Ohms. I remember my 1ohm setup when i would burp it for SPL competition would drop down to allmsot 1/3Ohms (of course this is for a microsecond. If your multimeter has a MAX HOLD option (it will hold the max value it reads) this won't be a huge issue, otherwise you gotta be quick
96 Camry I4 with evo kit and custom everything else.
2005 4runner Sport V6 - Stock
2004 Camry Solara SE V6 - My new baby
So I got my amp fixed. I took it to a repair shop and it's been over a week and the problem hasn't returned. They told me that they just did maintenance on it and cleaned up some corrosion and resoldered some traces on the circuit board.
The boom is back!
