Newbie needs tips, advice for installing subwoofer in 08 9th generation corolla
Right now, i'm interested in putting a sub into my 2008 corolla. I did the head unit a few months ago and it was pretty easy, so i figured, why not get more punch.
While messing around behind the dash, i found a gap in the paneling where i can route the RCA preouts to the sub, so that's done, but there's still a few questions I have before I jump in.
1) How do I route the power cable from the battery to the trunk? Do i need to drill a hole in the firewall or is there an existing gap I can use?
2) I haven't taken a good look yet but is there any bolt in the trunk that you'd recommend for grounding? And also, when I do ground it, all I need to do is sand down the area around the hole to the bare metal and tap the cable on, right?
3) I'm looking at subs in the range of 6"-12". When my friend installed his (rather small) powered sub, he drilled holes into the car and secured the sub box with a bracket that was included with his sub. If I get a sub that's weighs heavy enough, would I still need to drill holes & mount the brackets, or would you say I should be fine not doing that?
