04 Corolla Speaker Install - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-20-2008, 01:42 PM   #1 (permalink)
Xan
Xan's Avatar
View Xan's Photo Gallery
Question 04 Corolla Speaker Install
Does anyone know how to remove stock front/rear speakers in an 04 Corolla, or a good site with help or a diy for it?
Xan is offline   Reply With Quote
Old 03-20-2008, 04:03 PM   #2 (permalink)
Sensible's Avatar
View Sensible's Photo Gallery
http://2k7corolla.blogspot.com/ There are pictures and good instructions here.
Sensible is offline   Reply With Quote
Old 03-20-2008, 04:16 PM   #3 (permalink)
Xan
Xan's Avatar
thanks a lot dude
Old 03-20-2008, 04:26 PM   #4 (permalink)
Sensible's Avatar
No problem.
Old 03-20-2008, 05:59 PM   #5 (permalink)
Xan
Xan's Avatar
hey i just got home from work, where i was blocked from that link, but when i go here it says blog cant be found... can you double check? thanks
Old 03-20-2008, 07:17 PM   #6 (permalink)
Sensible's Avatar
http://2k7corolla.blogspot.com/ Sorry about that! I messed up the link earlier.
Old 03-20-2008, 08:34 PM   #7 (permalink)
Xan
Xan's Avatar
ok sweet that one worked, and thats a lot of stuff to do, i could tell the rear looked like they were going to be hard, but is the 2007 instructions going to be the same as the 2004 ?
Old 03-20-2008, 09:59 PM   #8 (permalink)
Sensible's Avatar
Yes....all 9th gen. Corollas should be the same. I have the 6-speaker set-up in an 05' and it all is the same. I am using these instructions to do mine...just waiting for one more part I ordered.
Old 03-20-2008, 10:11 PM   #9 (permalink)
Xan
Xan's Avatar
awesome, thanks again man, so its 6x9's/rear and 6.5's/front ?
Old 03-21-2008, 06:42 AM   #10 (permalink)
Sensible's Avatar
You got it.....6x9's drop right in just outline bolt hole pattern and drill, then use sheet metal screws to attatch( some adhesive type sealant is helpul to make good seal ie...silicone,caulk,etc.) Front 6.5" work,shallow mount is better for any clearance issues,. Just drill out rivets , line up speaker , outline holes ,and drill Use sheet metal screws. Same thing with the adhesive as above,,it helps reduce vibration and also gets a good seal around the speaker for a little better sound.
