what he means is why did you get an 8 ohm sub, not 4 or even 2 ohms, your amp pushes 150 rms into 4 ohms, only 75 into 8, and 300 into 2 ohms, although it may not be stable to 2 ohms. An 8 ohm sub is probably meant to be wired in parallel. 4 of these in parallel would lead to a 2 ohm load on the amp, and two in parallel would be a 4 ohm load.
This sub is halving the amount of power your getting from that amp, it will sound fine, it's just not efficient.
As far as the speakers, if the H.U. really has 22 W RMS they will sound alright off it, but I doubt it does. They are pretty efficient though. They would sound better off an amp, but unless you are listening to it loud it should sound fine. Also, because you have a sub it takes some load of the speakers for bass, so if your H.U. can, send less bass to the speakers.
