Parrot Kit and Parrot CK3000 install in a 2001 Gen5 with jbl stereo - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-23-2008, 04:07 PM   #1 (permalink)
View mysilvercamry's Photo Gallery
I got my mom a parrot bluetooth ck3000 car kit for Easter/ Mothers day and picked up a harness from parrotkits.com for her Camry. She has the JBL speaker system and one of the instructions in order to go through the cars speakers you need to tap into a speaker wire or two depending on the setup you want. Does anyone know the color of the speaker wires? Should i tap into them with the toyota radio plug? Thanks for the help!!
J
mysilvercamry is offline   Reply With Quote
Old 03-25-2008, 12:22 AM   #2 (permalink)
Gear Head's Avatar
View Gear Head's Photo Gallery
The Parrot kit must be placed in-line with the speaker wires. If you dont have an adapter harness made speciffically for the toyota you will need to cut and splice into the factory wiring. Look behind her radio and see if she has 1 plug or 2 if she has two then no problem splice in behind there. If she only has 1 (which she probably does because of the JBL) then you need to find the amp and tap into the output side of the amp otherwise you will have problems.
Gear Head is offline   Reply With Quote
