what size wire from amp to ground? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-27-2003, 01:51 AM   #1 (permalink)
View crazy_camry's Photo Gallery
the question above. should the ground wire for the amp be the same as my power wire (4g)?
crazy_camry is offline   Reply With Quote
Old 10-27-2003, 04:40 AM   #2 (permalink)
Beams SV21
da_horse's Avatar
View da_horse's Photo Gallery
yeah that should be fine....just ground it properly
huy
da_horse is offline   Reply With Quote
Old 10-27-2003, 05:05 AM   #3 (permalink)
thanks for the reply. i thought it would be good to have it this size, just making sure.
Old 11-07-2003, 02:16 PM   #4 (permalink)
View theanimal_650's Photo Gallery
Your ground wire should always be the same size or bigger than your power wire. You should also upgrade the wiring from your negative terminal on your battery, the wire on the alternator and the ground to your engine to the same size as the amp wire or bigger.
Startin to wonder about this Avalon!
theanimal_650 is offline   Reply With Quote
