08 Camry LE - Amp,LOC & Sub Install(w/Pix & video)...
Yesterday my son & I installed a LOC, amp & a subwoofer.The LOC is from P.A.C.(PAC Trunk L.O.C.),the amp is a Profile Baja rated 200w @ 4ohms x1/350w @ 2ohms.Right now it's running @ 4ohms and the subwoofer is a Dayton 12" Quatro which I got on sale for $70 from Parts Express.The enclosure was a previous one I had laying around which was bigger,cut it up & salvaged for a final .85cf of space.The carpet is on order and should be here during the week sometime.The amp was installed under the rear deck along with the LOC.Maybe sometime(if I can find time)in the spring or summer I want to do a fiberglass enclosure in the corner of the trunk for more stealth.I'm happy with the over sound I get with just a subwoofer added.It took us about 6hrs. total ,most of that was spent laying on my back in the trunk.Anyways if u have any questions feel free to ask.Here's the link to the pix... http://smg.photobucket.com/albums/v4...#37;20Install/
as gsman said it could be a problem if you start pushing the amp, if it works than cool, if you ever have a problem with it you could just suspend a platform a few inches lower and hook the amp to that right side up. enjoy the new system.
I was just planning the same thing for my 07 SE. I now see where to run the power cable through the firewall. Can you tell me where and how you picked up the remote power on for the amp. I was thinking about taking out the head unit and splicing into the radio power.
With this setup I did not have to take the HU out.Everything was done in the trunk hence the name ''TRUNK LOC''.All in all it took me & my son about 4hrs. from start to finish.I posted a pic of the instructions that came with the LOC,simple straight forward & works like a charm.I will say that adding a sub really makes a difference and I'm mostly surprised with how the sub just blends in with the stock system.The sub is only getting 200w @4ohms,I'm planning on getting a dual 4ohms sub so to take advantage of the 350w available @ 2ohms.Anyways heres the pic any Q.'s feel free to ask.
Thanks, that helps a lot. I'll check the Scosche LOC I have and see if it has trigger as well. I like the PAC for that feature, otherwise I will pop out the head unit and get my amp trigger from there.
There are L-brackets on each side(not seen in pix,added this weekend) ,they're screwed to the box then secured to the sheet metal.The box was wedged in with no brackets for about a week & didn't budge.It's better to be safe than sorry especially with all the potholes. Oh all the wiring has been cleaned up using split loom & zip ties.
