2000 camry fire wall - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-21-2008, 08:50 PM   #1 (permalink)
'00 V-6 Camry's Avatar
View '00 V-6 Camry's Photo Gallery
4th Generation 2000 camry fire wall
hey how y'all doing got a quick question, and i did try to find this first, but is there a way to go through the fire wall with a 4ga wire with out drilling a hole ?
FloridaBoy lost in North Dakota
'00 V-6 Camry is offline   Reply With Quote
Old 04-21-2008, 09:26 PM   #2 (permalink)
View frojoe's Photo Gallery
in most cars the factory wiring goes through a gasket on the drivers side. assuming your car will be similar to my 93 camry(which it very well might not be) I was able to force 4 gauge through the factory gasket. I had to remove the drivers side wheel and then the wheel well to expose that side of the hole. The other side was visible from the drivers side floor. I got a coat hanger through and then taped on the wire and pulled it through. good luck
frojoe is offline   Reply With Quote
Old 04-22-2008, 02:36 AM   #3 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Look near the strut mount and the brake reservoir. You should see a bundle of wires going through a plastic grommet into what looks like the wheel well. YOu can follow this bundle of wires into the car.
2007 Camry 2.4L 5M
