What sound System? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-06-2003, 10:10 PM   #1 (permalink)
WHAT???
View supra06's Photo Gallery
What sound System?
hey,
I gotta a question will Kicker CompVR 12" 400 RMS sound better then Rockford Fosgate HX2 12" 500 RMS? going into a ported or a bandpass box? and what should i power them up with?
thanks. need to know.
supra06 is offline   Reply With Quote
Old 11-06-2003, 11:32 PM   #2 (permalink)
Luc
View Luc's Photo Gallery
A better question would be which one is louder, not which one sounds better, since it's hard to differentiate clean sound when only bass notes are played. I can't comment on the RF's, but on the CVR's, they are pretty nice, all with DVCs. If you want LOUD, check out Kicker's site under the technical information link. You can build a slot-ported box that will be LOUD. But a single sub in a slot-ported box is about the same size as two subs in a sealed box. Bandpass will be the loudest as long as it's designed properly, otherwise, it will sound very sloppy. Get a good, reputable 500-W amp.
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
Old 11-08-2003, 07:03 PM   #3 (permalink)
WHAT???
luc,
what if i get 10"? what kind of amp would i need. Im thinking of 10" now, instead of 12".???
thanks.
Old 11-08-2003, 07:51 PM   #4 (permalink)
I get angry when Im sober
Stealth's Avatar
View Stealth's Photo Gallery
12" Comp VR in a sealed box would be nice. I wouldn't suggest getting smaller than a 12" sub... most 10s won't play as low as 20 Hz. I've never heard HX2s before, but I know the Comp VR can take more power than 400 RMS.
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
Stealth is offline   Reply With Quote
Old 11-09-2003, 12:41 PM   #5 (permalink)
WHAT???
i will be now getting the compvr's 12", but i have heard that if u put them in a ported box would hit harder, is this true? and should i get a RF or Kicker amp? mono or 2 channel?
thanks.
Old 11-09-2003, 02:06 PM   #6 (permalink)
Stealth's Avatar
They will get louder, but it won't be as punchy or accurate... I still suggest a small sealed box.
Old 11-10-2003, 12:12 PM   #7 (permalink)
WHAT???
what kind of amp should i get for the 12" compvr? how many watts, RF or Kicker?
thanks.
Old 11-10-2003, 06:35 PM   #8 (permalink)
Stealth's Avatar
There's more brands than RF and Kicker... just find a mono amp that puts out 400-500 watts RMS
Old 11-10-2003, 10:33 PM   #9 (permalink)
View oibone781's Photo Gallery
If I remember correctley the 10's are silver, if they are silver don't get them, they don't really give you that boom boom bass more like pow pow, you ever ran bass through you 6x9's? thats how it sounds....and when I heard them it was 2 10's in a sealed box..
oibone781 is offline   Reply With Quote
Old 11-11-2003, 11:26 PM   #10 (permalink)
Luc
I'd go with a ported box whenver I can, as long as there is room. Not only you get a deeper bass output, but also a higher volume, as much as 3-dB. It will be "punchy and accurate" when the amp driving the sub(s) is set up properly. If the subs weren't able to produce good bass output, why would companies like JL or Kicker have dimensions to build a ported box? All subs will play down to 20-Hz, but they don't have the same output as compared to 45-Hz, and a test tone CD can prove that.
Old 11-12-2003, 08:35 PM   #11 (permalink)
WHAT???
hey,
how would i know if they are "silver" are they only in 10" or both 10" and 12"?
thanks.
Old 11-12-2003, 10:20 PM   #12 (permalink)
both 10 and 12
Old 11-13-2003, 12:12 PM   #13 (permalink)
WHAT???
then what sound system should i get?
Old 11-13-2003, 01:32 PM   #14 (permalink)
sargdesigns
arcasmachineracing's Avatar
View arcasmachineracing's Photo Gallery
A very loud and powerful system of course!
Brandon
arcasmachineracing is offline   Reply With Quote
Old 11-13-2003, 02:07 PM   #15 (permalink)
sargdesigns
Here we go, get these:
Brandon
