Here ya go.
12volts: white, +, ignition harness
Starter: black/white, +, ignition harness
Ignition: black/yellow, +, ignition harness
Power Lock: blue/black, -, passenger kick
Power Unlock: blue/red, -, passenger kick
Notes: Green/white on models with factory alarm.
Parking Lights+: green, dimmer switch or kick
Parking Lights-: lt. green or white, steering column
Door Trigger: red/white or black, -, plug at top of fusebox
Notes: Use the Black in a 2 pin connector at the top of the fusebox on versions without a sunroof. On cars with a sunroof use the red/white in a 4 or 6 pin connector in the same location. When adding dome light supervision use the door trigger wire and relay isolate to keep ground from entering the fusebox side of the wire or unlock will not function properly.
Trunk/Hatch Pin: red/white, -, light or pin in trunk
Notes: On the wagon version the rear door is tied in with the door trigger wire.
Hood Pin: red, -, anti-theft ECU
Notes: The anti-theft ECU is located high in the drivers side kick panel.
Tachometer: black, ac, check connector
Horn Trigger: green/red, -, steering column
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
