Yeah, there are many amps that will accept speaker level inputs or you could use a hi to low convertor which converts your speaker level outputs from the hu down to preamp level for the amp input. Either way, the sound quality is no where near what a hu with pre-outs would be capable of. My suggestion would be to swap out the hu to something that has pre-outs and an amp to along with it. It'll sound much better. Also, it doesn't sound like you're planning on using a crossover so make sure your amp has one built in so you only send bass to the sub...again, it'll sound better that way.
