04' Corolla Power/Remote Wiring - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-05-2008, 03:00 PM   #1 (permalink)
View ryan_t888's Photo Gallery
Where does everyone route the power wire through the firewall on an 04 Corolla? Also what would be the best route for running the power through the rest of the car.
Which fuse is best to run the remote Wire from?
Does anyone have pics of any part of the install?
Any help would be greatly appreciated
Thanks
Ryan
ryan_t888 is offline   Reply With Quote
Old 05-07-2008, 11:16 AM   #2 (permalink)
Who had it done professionally and where did they run everything?
I'm looking at hiding 4AWG wire and I'm stuck until I find an answer.
Ryan
Old 05-07-2008, 01:59 PM   #3 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Look in the engine bay and in the wheel wells for where there is already wiring passing through the firewall. You can stick your power wire in these rubber grommets. If not, just drill a hole.
Then run it along the side under the plastic panels into the trunk.
For the remote wire, you can connect it to the cig lighter power wire.
2007 Camry 2.4L 5M
Old 05-07-2008, 02:14 PM   #4 (permalink)
Thanks for the reply. I'll check in those areas for a decent location.
Ryan
Old 05-08-2008, 06:07 PM   #5 (permalink)
Thanks, I know exactly how I am going to run the power cable. Now I just need to know where this specific fuse is located?
Is there any ignition controlled fuses behind the column above the pedals?
Ryan
Old 05-16-2008, 11:50 AM   #6 (permalink)
View merti's Photo Gallery
RE: 04' Corolla Power/Remote Wiring!!!
Yes! Nice information that you have shared with us.
Thank you very much!
Video Editing Software
merti is offline   Reply With Quote
Old 05-16-2008, 12:11 PM   #7 (permalink)
Installation is complete. 4AWG wire ran through the Grommet and speaker level inputs tapped from rear speakers at the deck. Remote Wire was fed to the stock deck power input so when the radio is on so is the amp.
An Audison SRX2 170w RMS was used with 1 10" Hertz ES 250 Sub. It has good punch and excellent sound quality.
Ryan
