As for no start conditions, the car should have an imoblizer in it. This prevents the car from being hot wired. If the used the simple way of putting an extra key in there, that might need to be adjusted. Here is what i find odd. If you say you put your key in and turn it to run and hit the brake and the car turns off, that means there is something wrong with the wiring. By default, the system acts as though your turning the key through different positions, so if the key is in and turned 2 clicks, it should act jsut the same as the remote start. If you only turned it 1 click, then the engine will turn off cause it shouldn't normaly be running in that position. The imobolizer will kick in usualy 3 - 5 seconds after engine start, so if you car has been running for 5 minutes ok, then that's not it either. As for the fuse blowing, it soulds like a wire that was tapped that should have been. As far as i know there shouldn't be any ECU wires used except for maybe the tach signal. perhaps you need to have it removed and reinstalled at a different shop by a different installer.
96 Camry I4 with evo kit and custom everything else.
2005 4runner Sport V6 - Stock
2004 Camry Solara SE V6 - My new baby
