double-din with scosche dash kit - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-17-2008, 12:23 AM   #1 (permalink)
Kenneth Noisewater's Avatar
View Kenneth Noisewater's Photo Gallery
I am going to buy the Clarion MaX685BT....I way planning on using the scosche dash kit...i wanted to make sure that this set-up will work..
Scosche TA2053B / TA2053
Crutchfield said that."Fold-down face receivers may not fit your vehicle. Please verify that your new receiver does not have a fold-down face." the screen on the max685bt slides down and out..Hoping someone can tell me if it will work before i spend all this money to find out it doesnt..
Kenneth Noisewater is offline   Reply With Quote
Old 05-18-2008, 01:21 AM   #2 (permalink)
never mind
i verified that it will work..if you guys want to see what the finished product looks like i will post pictures after i do the install....i'm also installing a new grille and mounting driving lights behind the grille. I'll post pics when its all done!
Old 05-26-2008, 11:28 PM   #3 (permalink)
Help please!
ok....i just finished doin the install and it looks good...BUT......when i put in the piece of trim around the opening it doesnt allow for the unit to open? I'm not sure if its just that it needs to be adjusted a little bit or it just doesen't work...some please give me some advice.
Also, I tried to bypass the parking brake using a switch and it didnt work...its pretty annoying ...got any idea's?
Old 05-27-2008, 08:45 AM   #4 (permalink)
I smell McNuggets
[SMAN]'s Avatar
iTrader Score: 7 reviews
View [SMAN]'s Photo Gallery
You'll need to post some pictures of your problem so we can see why it's not fitting...
96 Camry I4 with evo kit and custom everything else.
2005 4runner Sport V6 - Stock
2004 Camry Solara SE V6 - My new baby
[SMAN] is offline   Reply With Quote
Old 05-27-2008, 11:07 AM   #5 (permalink)
bigloubumpin's Avatar
Gameroom cash: $151645
View bigloubumpin's Photo Gallery
X2
bigloubumpin is offline   Reply With Quote
Old 05-28-2008, 04:55 PM   #6 (permalink)
here it is
Okay... I fixed the problem... It now opens ok...but here are the before and after pics.
Before:
After:
Tell me what you guys think...
On another note im still having the problem with the dvd player..I cant get it to play at all..All it says is "audio only"...I ran the ground from the head unit to one side of a switch and the other side of a switch goes to the lamp wire of the parking brake... when the car is on i can flip the switch and the brake light shows up on the dash but it still wont show video? WTF
Old 05-28-2008, 05:08 PM   #7 (permalink)
I smell McNuggets
[SMAN]'s Avatar
thats probably cause you did your wiring wrong. basicly, all you did was make a switch to turn a lightbulb on and nothing more. there is a parking brake wire, you need to run that to the parking brake switch. As for fitment, it looks like it's sticking out a little far, but it's hard to tell with a head on shot.
Old 05-28-2008, 05:22 PM   #8 (permalink)
where?
how do i identify the correct wire?
Old 05-28-2008, 10:42 PM   #9 (permalink)
I smell McNuggets
[SMAN]'s Avatar
Well on the audio harness it should be labled, and then just use a wiring diagram for your make and model.
Old 05-29-2008, 05:07 AM   #10 (permalink)
not what i ment
i know the e ebake wire from the head unit is the grass green color...iwas trying to identify the the trucks ebrake wire cause you said iwas tapped into the wrong wire. i was trying to figure it out w/o having to take down the knee wall on the drivers side but i was having trouble doin so.
Old 05-29-2008, 05:57 AM   #11 (permalink)
jay7108's Avatar
View jay7108's Photo Gallery
I believe it is the black wire from the harness I have a Kenwood 8120 I just installed 2 weeks ago and that is what I did.
jay7108 is offline   Reply With Quote
Old 05-29-2008, 06:13 AM   #12 (permalink)
I smell McNuggets
[SMAN]'s Avatar
Black wire in aftermarket harnesses is allways chassis ground.
Old 05-29-2008, 07:41 AM   #13 (permalink)
gsman73's Avatar
View gsman73's Photo Gallery
just ground the ebrake wire on the radio harness and be done with it, you don't need to use the ebrake wire from the car at all and you don't need a switch the company only puts ebrake wires on the radios for liability reasons.
gsman73 is offline   Reply With Quote
Old 05-29-2008, 09:09 PM   #14 (permalink)
probally should have told you this
i should have started the thread by telling you guys that i tried to just ground the ground wire from the harness and it didnt work....but just fo fun i tried it again and it didnt work again...please help
Old 05-30-2008, 10:56 AM   #15 (permalink)
gsman73's Avatar
then it may be like the new pioneer radios, you may need to switch around a wire or two google your radio and see what comes up. Let me know what the model number is and I'll try to come up with something.
