Battery/ Fuse question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-04-2008, 09:32 PM   #1 (permalink)
Man of the Year
View haschen's Photo Gallery
Probally not the right section for this but im pretty desperate. Just try not to give me to much shit haha, any help would be good thanks
Ok, went to get a new battery, the ground would not reach so i had to extend them, got it done. HOWEVER. I blew a fuse (A80, one with two metal claps) I can get one bolt out but the otherside is hidden behind a piece of plastic. There is also another empty slot right next to the blown fuse, can i put the new one there? But i still dont know how to get the other damn bolt. I HAVE NO IDEA how to get it out and change it. Untill one of ya tell me its gonna sit at AUTOZONE haha. So please help a brother out. The A80 fuse or 80A not sure is in the fuse box under the hood. Please help guys thanks
haschen is offline   Reply With Quote
Old 06-04-2008, 10:03 PM   #2 (permalink)
View toyomoho's Photo Gallery
Should be under the hood, look for a small plastic box(s) next to the fender most likely drivers side. It will contain fuses of the same design.
The fuse is bolted to the wires from below. Remove the fuse box and turn it over to access the bolts.
And the fuse itself is mounted on a removable insert which either comes at the top or bottom of the fuse box (not sure which). Perhaps you can tell by looking. Once out you can unbolt the wires.
The other fuse box may be behind the drivers side ash try but should only contain small amp fuses.
If you have the owners manual it may contain the info and location.
Old 06-04-2008, 10:53 PM   #3 (permalink)
Man of the Year
Your the man. Ill give it a try.
Anyone eles? Lets hear some suggestions. Gonna try it in the AM.
THANKS
