Scion SNS system in my 2005 Tacoma - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-27-2008, 01:37 PM   #1 (permalink)
View Sideways's Photo Gallery
I have an opportunity to purchase a SNS unit from Scion and am contemplating putting into my 05 Tacoma.
Would this be a plug an play install other than the bezel and GPS antenna?
Sideways is offline   Reply With Quote
Old 07-30-2008, 07:46 AM   #2 (permalink)
Taco Salad!!
roboots21's Avatar
View roboots21's Photo Gallery
Hey man,
I did a similar mod to my Tacoma. I put the Premium Scion head unit into my truck, which I believe to be the same mounting and size as the Scion Nav. System. It does take a little bit of modification to get it to fit correctly.
First of all, it is plug and play. All of the Tacoma plugs (Steering wheel controls, etc.) plug right into the Scion unit. I plugged my premium unit in and it worked right from the start.
There was some minor fabrication (or so to speak) to get the head unit to fit. First of all, I bought the Scosche mounting kit for the Tacoma, and modified it to fit the Scion sized stereos:
Then, after I got the mounting kit dremeled, modded, and painted black, I had to modify the brackets for the stereo for them to position the stereo correctly within the bezel. Here is the test fit of the stereo with the mounting kit removed. The stereo actually doesn't mount using the scosche kit, it mounts on its own, unlike the regular Tacoma stereo. The schosche kit is more or less just a stereo surround in this case. Here is a pic of the mounted stereo, then a pic of the stereo with the surround all installed:
So, it can be done, but it does take some work...
On that note...I have since upgraded my stereo to an aftermarket unit, so I am no longer using the schosche mount kit or the original stereo brackets I modified to fit the Scion head unit. If you would be interested, I would sell the mount kit and brackets. I no longer need them nor do I think I will ever use them, they are just sitting in my workshop collecting dust.
Your best bet, if interested, is get on a Scion forum and verify that the two units are the same faceplate size and use the same mounting (which I am pretty sure they are), and then let me know if you are interested in the parts that I have. I just wanted to let you know that it can definately be done.
Hope I could help! Good luck in whatever you choose!
'07 TRD Sport DC LB
K&N/Grillcraft/Extang/Sirius/Supersprings/Bilstein/URD
DTRL/Flowmaster/Pioneer/Polk/JL/Nitto/Moto Metal/C2C
roboots21 is offline   Reply With Quote
Old 07-30-2008, 01:48 PM   #3 (permalink)
Thanks for the reply but it never fails, that's how my luck runs, a day late and dollar short.
I would have gladly bought the kit from you but
I already have the scosche kit and had to enlarge the opening in the bezel for the Nav unit to fit.
I will post pictures as soon as the install is done.
Your install looks nice and clean!
Why did you decide to go aftermarket after installing the Scion unit?
Old 07-30-2008, 02:26 PM   #4 (permalink)
Taco Salad!!
roboots21's Avatar
Well if things don't work out and you mess something up on the install let me know, my parts aren't going anywhere...
I went aftermarket because I wanted a more adjustable EQ that what was on the Scion unit. It was a great unit, just wanted more adjustability. Plus, I wanted hands-free bluetooth and my new head unit has it, and the iPod integration on the new head unit I got (Pioneer FH-P8000BT) has much better iPod navigation.
Thanks for the words though, and look forward to the pics!
'07 TRD Sport DC LB
