Amp & Sub Wiring to Stock Stereo - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-01-2008, 12:38 PM   #1 (permalink)
日産自動車パワー!
JMSports's Avatar
View JMSports's Photo Gallery
Problem Solved.
マイクジョンソン.___________________私は日産マキシマ自身ビッチ!
JMSports is offline   Reply With Quote
Old 08-03-2008, 06:05 PM   #2 (permalink)
View frojoe's Photo Gallery
First of all, that amp is 100 watts RMS per channel, or 290 bridged, and the subs are 600 watts RMS. Peak power is a useless rating, you need to look at RMS ratings.
As far as wiring, make sure you fuse the 12v positive as close to the battery as possible, within about a foot. For the ground make sure you ground to a substantial piece of metal, and remove any paint first. You might want to look into doing the big 3 as well, but thats up to you.
The wiring from the radio to the amp will depend on weather or not the amp has speaker level inputs. The turn on lead could be run from any switched 12 volt source, but then the amp would be on whenever the car was. An LOC might have a turn on lead as well.
The wire from the amp to the subs should just be speaker wire, around 12 or 14 gauge.
To help more, I need to know if that amp has speaker level inputs.
frojoe is offline   Reply With Quote
Old 08-03-2008, 08:23 PM   #3 (permalink)
日産自動車パワー!
JMSports's Avatar
System all hooked up.
