2 amps, 1 ground? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-02-2008, 07:36 PM   #1 (permalink)
yosh2000's Avatar
View yosh2000's Photo Gallery
2 amps, 1 ground?
just purchased a multiple amp install kit. it came w/ a distribution block to have both amps grounded to the same place.
it is ok to ground both amps through the distro block to the same spot, or should i ground each amp separately?
also, mounting the amps under seat, would the seat bolts be a good ground?
thanks for the help...
Want LEDs swapped in your cluster in Denver (or anywhere for that matter!), see here!
Want an OEM HID retrofit (no PNP crap!), see here!
yosh2000 is offline   Reply With Quote
Old 08-02-2008, 07:57 PM   #2 (permalink)
View yrffej's Photo Gallery
simple grounding is one of those things that you can't over-do... i might even ground to frame and neg battery terminal.
if you have a volt meter? ck continuity between the seat-bolt, and frame and neg battery terminal.
'05 prerunner access trd sprt pkg1 w/tow & trd catback
yrffej is offline   Reply With Quote
Old 08-02-2008, 09:44 PM   #3 (permalink)
Old Man Tacoma
MikeS.'s Avatar
View MikeS.'s Photo Gallery
TacoTunes install of amp show it being grounded by a seat bolt.
MikeS.
Escaped from Kalifornia in 1998
Now living in West by God Virginny
A Master Mason under the Grand Lodge of WVa
MikeS. is offline   Reply With Quote
Old 08-02-2008, 10:10 PM   #4 (permalink)
כל הכבוד לצהל
Holling's Avatar
View Holling's Photo Gallery
To answer your question, one good ground will work fine.
Holling
2007 Sequoia Limited
2008 Tacoma Double Cab TRD 4x4
ΜΟΛΩΝ ΛΑΒE
Holling is offline   Reply With Quote
Old 08-02-2008, 10:43 PM   #5 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $485305
View Zembonez's Photo Gallery
Ground is ground. If you have one or 20 it doesn't matter as long as it is a solid ground.
Zembonez is offline   Reply With Quote
Old 08-02-2008, 10:52 PM   #6 (permalink)
^the guitar, not the fish
bassman444's Avatar
View bassman444's Photo Gallery
True.
You have to make sure that the wire can handle it, too. I wouldn't use anything smaller than 10 guage. I used 8 on mine.
'06, PreRunner, V6, SR5, TRD Sport, Access Cab
It's better to remain silent and thought a fool than to speak up and remove all doubt.
Tom Jackson - Birmingham, AL
bassman444 is offline   Reply With Quote
Old 08-03-2008, 03:12 AM   #7 (permalink)
View thoughthard's Photo Gallery
Factory grounds are a good place also...
thoughthard is offline   Reply With Quote
Old 08-03-2008, 05:05 PM   #8 (permalink)
View frojoe's Photo Gallery
seat bolts will probably be fine, but wherever you ground make sure you grind off any paint or coating first.
frojoe is offline   Reply With Quote
