radio help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-18-2008, 04:08 PM   #1 (permalink)
My leather so soft
Gameroom cash: $103510
View the94camryman's Photo Gallery
radio help
well i dont have the time at the moment to search through a bunch of posts but i will later.
but basically my pioneer deh-p3100 headunit in my 94 camry likes to turn up the volume on its own (to max volume), and then not respond when i press the buttons.
the94camryman is offline   Reply With Quote
Old 09-18-2008, 04:40 PM   #2 (permalink)
Got a FC3S!
Paseo15psi's Avatar
View Paseo15psi's Photo Gallery
Try cleaning the connectors for the face to the radio. Also, you can take apart the face and clean the PC board and micro switches with electronic contact cleaner or alcohol if in a pinch. Alcohol has too much water though, so try to avoid it if you can. That actually is a common problem for a detachable face radio.
Paseo Performance Information PM me if you need me...
Paseo15psi is offline   Reply With Quote
Old 09-18-2008, 09:38 PM   #3 (permalink)
My leather so soft
really? i did not know that was so common. learn somethin new everyday. ill give that a try though. i was actually gonna take the thing apart and make sure everything was connected as it is supposed to and fix anything if it was broken. figured a wire just came undone and was gonna solder it back on.
