Pickup sub setup - Page 3 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-25-2008, 11:32 AM   #31 (permalink)
berry79's Avatar
View berry79's Photo Gallery
Yeah, thats way to big. I don't even know if they make speaker wire that thick. I have used 12 guage and maybe seen 10, but definetly never seen 8.
berry79 is offline   Reply With Quote
Old 11-25-2008, 02:50 PM   #32 (permalink)
Quickywd01's Avatar
View Quickywd01's Photo Gallery
I'll just use some of the wire that comes with the amp wiring kit.
1990 Deluxe Xtra 4x4 3.0L auto
Quickywd01 is offline   Reply With Quote
Old 11-26-2008, 01:22 AM   #33 (permalink)
View Fobanginvtek's Photo Gallery
Originally Posted by Quickywd01 View Post
Hey, I have a toyota pickup xtra cab and want to get a single 12" sub. I was thinking about the type-r 12" 1224d and run it in 2 ohms. What amp and what size (cu. ft.) box should I get?
I was looking at these two. Any help would be appreciated. Thanks.
http://www.alpine-usa.com/US-en/prod...model=MRP-M850
http://www.alpine-usa.com/US-en/prod...model=MRP-M650
My friend actually has a Toyota xtra cab and had a 10'' Type R, and JUST got a 12'' Type R today. He has it hooked up to the Alpine 850 and it pushes good and hard.
2007 Super white Camry CE
JL 13w7 in Prowedge box/Hifonics Brutus 1600rms
HID 8k and SE mesh grille
Fobanginvtek is offline   Reply With Quote
Old 11-26-2008, 10:12 AM   #34 (permalink)
Quickywd01's Avatar
Awesome! I hope 1000w does the same.
Old 11-26-2008, 12:11 PM   #35 (permalink)
Quickywd01's Avatar
This is very helpful http://www.bcae1.com/spboxnew2.htm I'm making my box to be 13"x13"x15.465" external dimensions. That comes out to 1.07 cubic feet minus the .07 the sub takes up and it's exactly 1 cubic foot or air space.
Last edited by Quickywd01; 11-26-2008 at 02:02 PM. Reason: http://www.bcae1.com/spboxnew2.htm
Old 12-03-2008, 08:16 PM   #36 (permalink)
Quickywd01's Avatar
How should I set the settings on the back of the amp for break-in?
Old 12-04-2008, 11:15 AM   #37 (permalink)
berry79's Avatar
I normally set everything up from the beginning and then just listen at 50% volume for a few days to break them in, and thats it. To set the amp, I would start with the gain all the way down, then increase the radio volume to 3/4, make sure there is no distortion, if so, turn down volume untill distortion is gone. Next, adjust the gain on the amp to a setting right before it distorts. On the amp you will have to adjust the LP crossover, and I believe a bass boost setting also. Adjust the LP setting untill it is just low frequency bass playing from the subs, you don't want them playing any high frequencies. As for the bass boost setting that I believe is on that amp, just adjust it to your liking. When making these adjustments in the beginning don't worry about damaging the speaker. Basically the break is the time it takes for them to play there optimal sound. New speakers are stiff, once they loosen a little, the sound alot better.
