HIDs affects radio??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-01-2008, 03:24 AM   #1 (permalink)
i like beef
Kobang's Avatar
View Kobang's Photo Gallery
I'm wondering if anyones HID headlights affects the stock radio. Like when i turn on my headlights i get a good amount of static and it suks. Anyone?? any fixes? I love my lights too much. what to do?
Kobang is offline   Reply With Quote
Old 10-01-2008, 10:22 AM   #2 (permalink)
View wing103's Photo Gallery
I have the same problem here, I have HID headlight & fog light. When I turn it on...... I cannot listen to the radio.................becasue the static......... So I have nochoice, I have to use the CD or play MP3 from my phone using bluetooth to the OEM stereo...................
I will like to know any fix on this too.
By the way I feel your pain.
wing103 is offline   Reply With Quote
Old 10-01-2008, 12:33 PM   #3 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $2513100
Could be a problem with grounding. I'd check the battery ground and also the ballast for the HIDs. If that doesn't solve the problem you could try adding a noise filter to each ballast. It's an unusual problem with a lot of potential culprits, but those are a couple of ideas. Let us know what happens....
TrailDust
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is offline   Reply With Quote
Old 10-01-2008, 01:24 PM   #4 (permalink)
i like beef
Kobang's Avatar
TrailDust
Where would i get a noise filter?
Old 10-01-2008, 02:22 PM   #5 (permalink)
Do you feel lucky?
TrailDust's Avatar
I had a brain fart about putting a noise filter on the ballasts. Instead, you could put one "upstream" to eliminate noise from the power source. Try this link:
http://www.mobilevideo4less.com/Merc...tegory_Code=NF
I won't guarantee that it'll work, but perhaps worth a try. Again, HIDs causing interference is a problem with many potential causes. Let us know if you solve the problem.
TrailDust
2002 Avalon XL
Old 10-17-2008, 04:13 PM   #6 (permalink)
Avarollin?
Jigg007's Avatar
Gameroom cash: $126250
View Jigg007's Photo Gallery
Ever resolve this issue?
Check grounds. if you can, ground the balast case. Maybe even a ground sheild arround the balast's output cables.
On a side note, I bet the AM works fine.
Click that cool picture above for my cardomain!
Jigg007 is offline   Reply With Quote
Old 10-18-2008, 01:25 AM   #7 (permalink)
View KooL's Photo Gallery
Your HID power isnt near any speaker wiring is it?
[CENTER]
KooL is offline   Reply With Quote
Old 10-18-2008, 12:57 PM   #8 (permalink)
Avarollin?
Jigg007's Avatar
The problem is only when the radio is on, which means the EMI generated by the balasts from the high voltage switching is getting picked up by the FM antenna.
Beside,s theres not enough EMI to to make the speakers generate anything noticable.
If it were near an RCA line it would be much more severe because the noise created in the RCA line would be amplified from the amplifier.
