Do I need a more powerful alternator? Running 1 amp on stock 2008 Corolla alternator. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-02-2008, 12:34 AM   #1 (permalink)
View driving90's Photo Gallery
Exclamation Do I need a more powerful alternator? Running 1 amp on stock 2008 Corolla alternator.
I'm planning on installing an amp & sub into my 2008 Corolla this weekend. Right now, the Corolla is using the stock 80A alternator.
The amplifier is mono and is rated to work at 300 watts X 1 at 2 ohms, 14.4V and at 150w x 1 @ 4 ohms, 14.4Vdc. The inline fuse for the amp is 50A. Here's the link to the specs page - http://www.kicker.com/06/kicker_home.html (since it's a flash site and i can't link directly to it, when the site loads, click on car audio, then Amplifiers, then ZX series, then Specs, then Mono, and finally ZX300.1.)
The sub I plan to wire to it is an 8" Bazooka tube running at 4 ohms - http://www.sasbazooka.com/products/m...Subwoofer-P150
Do you guys think I'll be fine? Or should I get a bigger alternator?
2008 Corolla CE USDM Mostly Stock
A/V Upgrades : Kenwood KDC-MP135 Head Unit, Pioneer INNO Portable XM Satellite Radio, Sirius Stratus SV3 Satellite Radio, Bazooka Bass Tube (Model NOS8) driven by a Kicker ZX300.1 amp @ 4 ohms, 150W RMS.
Possible future mods: Short Ram Intake/new speakers
driving90 is offline   Reply With Quote
Old 10-02-2008, 01:21 AM   #2 (permalink)
bigloubumpin's Avatar
Gameroom cash: $150645
View bigloubumpin's Photo Gallery
That's a small setup which shouldn't put too much strain on the alty,u'll be fine .Make sure to use proper size gauge for the power wire & ground for the amp.Good luck with install
bigloubumpin is offline   Reply With Quote
Old 10-02-2008, 01:55 AM   #3 (permalink)
View frojoe's Photo Gallery
with a 50 amp fuse and an 80 amp alternator you would blow the fuse before you maxed out the alternator. I guess with lights, a/c, radio, ect. running all at the same time, then maybe it would dim a little, but if they provided the fuse it probably has plenty of overhead, so you should be fine power wise...
frojoe is offline   Reply With Quote
Old 10-02-2008, 09:29 PM   #4 (permalink)
touringcamry's Avatar
Gameroom cash: $510625
That's not much power so you won't need a new alternator.
I had a 160W x 2 + 300W x 1 RMS running on my Camry's stock alternator just fine.
2007 Camry 2.4L 5M
