Originally Posted by bigloubumpin
That setup was in a '02 Camry which I traded in for the '08 I have now.The subs were 12'' EHQS from Elemental Design. I sold some stuff I had around the garage to fund the FG enclosure u see.The sub is only seeing 350w ,more than enough b/c the rest of the system is stock.I just needed some omf in my music & the sub blends in pretty nicely considering I have no processing at all.I actually like the sound stage of the stock system.The only gripe is when turned up it runs out of gas,especially the bass it litereally disappears.I'm assuming it's made this way in order to protect the speakers from blowing.As far as the bass goes I know from experience some of the sound waves do get trapped mainly b/c of the rear speakers.I occasionally have rear passengers so the speakers are staying.I just soundeadened the trunk area(with exception of the rear deck) over the weekend and it really makes a difference.My next upgrade will be the HU(Dble. Din A/V-Nav.) & front speakers,rears will stay stock.
Once you get your new HU, you wont have a problem with the bass cutting out when you turn it up. Its the circuitry of the OEM HU, to protect the OEM speakers. I had the same problem until I installed my Alpine HU.
How does your current setup compare to your previous IB one? Its probably not a fair comparison, being that it's 1 sub vs a pair. But which setup gave the better SQ?
