simple question... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-14-2003, 05:13 PM   #1 (permalink)
mnm66646's Avatar
View mnm66646's Photo Gallery
simple question...
can i run the same power cable for 2 amps.
or do i have to install another fuse and cable in order to make my other amp work?
Thanks in advance.
mnm66646 is offline   Reply With Quote
Old 12-14-2003, 07:14 PM   #2 (permalink)
View JaJay721's Photo Gallery
You need a distro block. One power wire to the block, two fuses, and two power wires out to the amps. Keep the distroblock close to your amps.
JaJay721 is offline   Reply With Quote
Old 12-28-2003, 12:14 AM   #3 (permalink)
Wazzaaap!
View mauibuilt59's Photo Gallery
you can also split and splice the power wire from the battery to two seperate power wires to your amp. Thats the cheap way...save about 20 bucks...haha
92 Camry v6 (3vz-fe)
mauibuilt59 is offline   Reply With Quote
Old 12-28-2003, 04:07 AM   #4 (permalink)
I get angry when Im sober
Stealth's Avatar
View Stealth's Photo Gallery
Uhm you need 3 fuses... well 3 if you use a smaller gauge wire after the distro block... like if you split 2 8 guages off of a 4 guage. But if you run a 4 and a 8 gauge off a 4 gauge you would only need to fuse the 8 gauge after the split. There should always be one fuse as close to the battery as possible.
www.knukonceptz.com
Wiring is so cheap there, there's no reason to go the cheap way on anything.
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
Stealth is offline   Reply With Quote
Old 12-28-2003, 08:51 PM   #5 (permalink)
Wazzaaap!
I only use one huge ass fuse before i split my 4 gauge into two 8 gauge. Never had problems since
Old 12-29-2003, 02:10 PM   #6 (permalink)
Why bother having a fuse at all then... its not doing you any good. If you want to protect your equipment get a distroblock and two fuses, one for each amp. Having a fuse twice the rating of what your equipment calls for will result in both amps blowing out if you ever have a power surge.
