Originally Posted by touringcamry
Is there any was to repair the foam surround? I accidentally gouged the surround cutting a bolt head off with a Dremel rotary tool.
It is only a gouge in the foam surround; there is no perforation in the foam surround. Heck, do I even need to make the repair? The gouge is about 1/2 in long. I have not hooked up the subwoofer since I damaged the sub.
No real harm done.
If it is only a small tear, repair it with silicone. Build up a layer over the front and rear of the tear and spread it at least 1/4 inch away from the tear. Once it sets up, add another thin layer over the "fix" Make sure you let it cure at least 24 hours before firing it back up. We fixed a sub with about 10 rips in the surround from my friend's Lab and it worked perfectly.
In answer to your original question, yes there are replacement surrounds all over Ebay. I've refoamed several vintage home speakers quite successfully.
