Oh your lucky, I've actually used both models, one on a Gen6 Camry and one on a IS300. Ranges for the 5701 is fairly typical for most alarms and remote starts, it's good enough for typical errands, like starting your car from inside a grocery store or retail store. But the range on the 5901 is actually one of the best, it is going to be about twice the range or so. It does depend on the situations you would use the ranges, for one car, the walking distance is farther, hence me getting the 5901.
I didn't bother hooking up the defroster or anything like that, since if I leave the switch to be on or having the heater or wipers on prior to leave the car, once it is started, those electronic parts will actually turn on if the on switch is on, ie seat heaters and headlights and stuff.
You definitely would not get 1 mile in range unless it's absolutely unobstructed and there isn't much other radio frequencies in the area.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
