Where do I run wires to dash 97 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-27-2008, 01:27 PM   #1 (permalink)
View super6logan's Photo Gallery
I'm trying to install an additional car horn in my 97 Camry LE and I need to add another button to the dash. I'm trying to figure out the best place the run the wire so I don't have to drill any holes. Does anyone know where the factory wires go to get from the engine to the dash?
super6logan is offline   Reply With Quote
Old 11-28-2008, 03:07 PM   #2 (permalink)
View frojoe's Photo Gallery
usually on the drivers side, the hole through the firewall will be up on the left, right above where a clutch would be. follow some of the wires from the battery back to that area and you can see where it will be. on my 93 camry I had to remove the inside of the wheel well to get to it and fish wires through
frojoe is offline   Reply With Quote
Old 11-28-2008, 06:31 PM   #3 (permalink)
Avarollin?
Jigg007's Avatar
Gameroom cash: $132050
View Jigg007's Photo Gallery
I'm sure the 96-97 avalon is very similar, there should also be a hole, atleast plugged with a rubber grommet above the brake pedal. Also there is an opening in the firewall for the engine control wires to run to the computer that you can use.
Click that cool picture above for my cardomain!
Jigg007 is offline   Reply With Quote
