Plz help.. 1995 4runner wiring questions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-28-2003, 07:40 PM   #1 (permalink)
View chasem's Photo Gallery
I have an alpine deck, in my 1995 4runner. Here is the problem, i wired it up like i was supposed to. (note: the AMP+ b and the Power antena pins were connected on my wire harness i bought.) But when i played cds, the rear speakers didnt work. When i turned on the the radio the power antena went up and the rear speakers worked. That led me to beilive that there was some sort of amplifer (i dont know why there would be my alpine puts out a good ~40w per channle back there) that needs to get turned on. So i then soldered the amp pin with the remote start and cut the amp/antena connection. Now the antena is always up (used to only come up during radio) and the rear speakers still onyl work when i use the radio. Anyone got any ideas?
THanks,
Mike
chasem is offline   Reply With Quote
Old 12-28-2003, 08:36 PM   #2 (permalink)
I get angry when Im sober
Stealth's Avatar
View Stealth's Photo Gallery
the antenna power wire should go to the antenna itself and nothing else...
the amp turn on wire you dont need so just tape off the end so its not exposed. I don't think you have any kind of amp in there.
Maybe this will help: http://www.installdr.com/InstallDocs...a/4Runner.html
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
Stealth is offline   Reply With Quote
Old 12-28-2003, 08:48 PM   #3 (permalink)
thanks for the quick response, i already figured it out though!!!!
turns out, on the factory harness i bought, the power window thing is mislabled! on the all webpages i looked too, its mislabled!! the power window and amp turn on wire are switched!
do you know of any sites that give tutorials on front/rear speaker installation on a 1995 4runner?
