Originally Posted by ryan_t888
Aha! I knew i've seen those silver boxes in autoshow cars before! :P
If you're not concerned with size, and just need it for testing purposes, use a battery charger. The big, stand up ones should be able to dish out quite a bit of current.
Also keep in mind, if you're using these to top off the batteries too, the charger is a constant current source, the battery is a buffer, and the amplifier is not a constant current draw.
So a larger amplifier or a smaller charger could be subsituted, as long as in the "quiet" time of the of the amplifier (or other system) is enough for the charger to juice up what the battery has lost.
If you don't need much, then you can use a PSU from a computer, you can get those in 500-1000W versions for fairly cheap, but they're commonly split across two power rails. Also, these are only 12V, so not much, if any battery charging would take place.
