Remote starter Camry 1995
Okay, I hooked up a remote starter from Design-Tech. Everything works fine except for the horn. The instalation diagram indicated wire is green/black. When I looked at the horn, the wire is green/white. I tried both of the wires but with no luck. Horn should sound when the remote starter is press or a lock/unlock button is pressed. I need a horn wire. I have a same remote starter model for my 93 Corolla and everything works fine. Thanks in advance for all the help.
Monkey123
