The CDA7995 is ONLY a preamp deck, so you will need to get external amps for it to work. Visit your local Tweeter to get it for $299.95.
On the 9815, there is a tag to wire up the 12V constant to a high current source, meaning, the 12V source in the steering column. The display is "busy," so it's advised to not connect it to the regular 12V in the dash. But the other two can use the 12V in the dash.
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
