I don't know much about loc's, because I've never used them so i can't be much help on the specifics of hooking them up. It sounds like your on the right track though.
As far as the switched 12v+, an aftermarket HU has a small wire, which is positive 12 volts when the head unit is on, and that wire is what tells the amplifiers to turn on. The stock head unit won't have this wire, so you need to tell the amp to turn on when you turn the radio on. Unless the LOC you get has a lead to do this, then you will need to take some other 12 volt positive from the car and run it to the amp. A switched 12v+ means it will only have power when the car is on, not all of the time, because otherwise it would stay on when the car was off, draining the battery.
