You would have to check the specs on the radio to see if it could handle a big hard drive like that. Of the USB ports I've seen, most are designed for the flash memory sticks (like 2 GB, 4 GB, etc.) The USB port might not be powered, and if it's not, it would not charge a battery-powered hard drive. But again, check the radio manual. Another detail to check is the file system format on the drive. The little ones are often still FAT32, while a big backup drive might be NTFS. The radio probably wouldn't like NTFS.
2009 Tacoma DC SB TRD Sport 4x4
Retired: 2000 Tacoma Xtra Cab V6 TRD Off Road 4x4
