It would depends on where you want the fiberglass to mold to in the trunk. If it's just a straight flat as a replacement for a side of the MDF box, then it's rather pointless, might as well use plexiglass instead. Thus, for those folds/bends that wood can't form to, fiberglass would be used. I'd suggest using at least 2 layers of fiberglass mat to build up the strength and allow 2-3 days for the resin to cure. Make sure it's done in a very well ventilated area.
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
