combining subs, amps, wattage? confuzzle
Hey guy's I have been wondering about this question for a while but i never really looked it up or needed to but my situation is ...
Say you have 2 4ohm subs. Here are jut some numbers, lets say its rated at 400wrms and 800w peak.
You have a amp that produces 200w x1 @ 4ohm or 400w x 1 at 2ohm. (just using a mono amp for the example)
So if you used just the one sub than your running it at 4ohm and giving it 200w.
But if it was 2ohm than it would be getting 400w. So say i combine both subs so they become 2ohm. Here is my problem. What exactly happens, does both subs actually get fed 400w? or is it split between the 2 like 200w each? or does both subs actually add up to 800wrms? you guys see what I'm getting at?
