Wiring 2 1 farad capacitors - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-12-2004, 09:54 PM   #1 (permalink)
The Wheel Guy
View iazuncupidi's Photo Gallery
Ok, Here's what im trying to do. Right now im running a 1 farad digital capacitor, But what im thinking is buying another 1 farad capacitor.
I was wondering how would wire up 2 capacitors?????? anyone have diagrams that i can print out. I will be building my amp rack soon and i wanna do it right the first time. I have gone thru so many systems and i finally got all the right stuff i want now.
Can anyone help????
Thanks
Kenny
iazuncupidi is offline   Reply With Quote
Old 01-12-2004, 10:33 PM   #2 (permalink)
I smell McNuggets
[SMAN]'s Avatar
iTrader Score: 7 reviews
View [SMAN]'s Photo Gallery
In general you would only want to have have 1 cap per amp, so if you got 2 amps, fork the wires, then run them into the caps before going into the amps.
96 Camry I4 with evo kit and custom everything else.
2005 4runner Sport V6 - Stock
2004 Camry Solara SE V6 - My new baby
[SMAN] is offline   Reply With Quote
Old 01-13-2004, 01:39 AM   #3 (permalink)
I get angry when Im sober
Stealth's Avatar
View Stealth's Photo Gallery
Yeah wouldn't it cause excessive cap wear if you had 2 hooked up to one amp? cause the one hooked up to the amp would drain the other one whenever it charges up or something?
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
Stealth is offline   Reply With Quote
Old 01-13-2004, 03:06 AM   #4 (permalink)
The Wheel Guy
im running a total of 3 amps....and 1 dc to ac 400watts inverter hooked up with a ps2 if needed.
2 Jl audio e2150 and 1 Jl audip 500/1. i have one cap then its forked into the 3 amps and the invertor.. but when i play at high volumes i get flickers on my interior lights...
so running 2 of them would have a little more reserve power just in case my bass hits..i thought about the extra batt but with what i have its not really needed. I would have just bought 1 2 farad cap bit since i already had 1 i just bought another one so that it equals to 2 farad when hooked up together.
click on my www button and look at my solara page and system set-up.. i have a diagram of how i have it hooked up right now...
i just need to see how the setup is like a wire diagram. i want to be sure to have it hook up right..
Old 01-13-2004, 03:11 AM   #5 (permalink)
Stealth's Avatar
most people say you only need 1 farad per 1000 watts RMS.. if that means anything
Old 01-13-2004, 03:24 AM   #6 (permalink)
The Wheel Guy
yea..but is 1000watts max..... im running about 900watts rms not including the invertor... some others have told me on other forums... but i feel that im not getting enough just out of one cap...
but anyone got any diagrams or pictures of a install they did or saw????
Old 01-13-2004, 10:22 AM   #7 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Wire the caps in parallel.
IE.... + of first cap to + on second cap. Same for the negative.
"Skoolin' the unlearned!"
Old 01-13-2004, 03:04 PM   #8 (permalink)
The Wheel Guy
thank you.. im going to give that a try and see if i have any problems...
thanks
