well fit can mean several things... you could certainly build a 6 cu ft box inside the trunk, but you may have a hard time just dropping in anything larger than a 4 cu ft box... to clear the trunk hinges, your box will have to be no wider than 46" (maybe slightly less). Height wise 16" or so... might be able to sneak in an extra inch or two (removing the rear speakers might help). Now for the box to drop right in... good luck with anything over a foot deep.
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
