Rosen AV7500 install question
So I just got the Rosen AV7500 dual dvd headrest system yesterday and I wanted to make sure I connect everything properly.
There are 3 12v wires and 3 ground wires. The ground wires are not the problem. The main (red) 12V acc can connect to fuse #25 which is a 10A and says rear entertainment system.
I'm not quite sure where to connect the Gray 12V switch-Fmm and the Blue 12V (Aux source). Another question is do I even have to connect them if I don't use the FMM or an Aux source?
Installing in a 2008 Toyota Highlander.
