can some explain how this is read - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-09-2009, 11:47 PM   #1 (permalink)
Biggg72's Avatar
View Biggg72's Photo Gallery
I tried to cut and paste the chart but it didnt work. the numbers match up to what was in the column.
1. Symbols (Terminal No.)
2. Wiring Color
3. Terminal Description
4. Condition Specification
1. MUTE (F19-1) - GND (F20-6)
2. O - BR Mute signal from radio receiver
3. Audio system is playing Changing
4. Above 3.5 V
Biggg72 is offline   Reply With Quote
Old 05-10-2009, 11:32 AM   #2 (permalink)
ShawnM's Avatar
View ShawnM's Photo Gallery
Hmm...Not exactly sure what your asking.
--Shawn
03 Camry LE
97 Lincoln MarkVIII LSC
67 Mustang
ShawnM is offline   Reply With Quote
Old 05-10-2009, 07:45 PM   #3 (permalink)
Biggg72's Avatar
i dont understand how to read the chart. it makes reference to 2 diff. plugs for #1. the color is that orange in the first plug brown in the second?
what im actually looking for is the wiring diagram for the jbl amp so i can run a amp and subs.
Old 05-10-2009, 09:44 PM   #4 (permalink)
日産自動車パワー!
JMSports's Avatar
View JMSports's Photo Gallery
So your looking for a wiring diagram for the AMP? Call JBL product support and ask them an in-depth explanation of the wiring. You really shouldnt need to modify any wires to hook a subwoofer to an amp, it should all be plug and play.
マイクジョンソン.___________________私は日産マキシマ自身ビッチ!
JMSports is offline   Reply With Quote
Old 05-10-2009, 10:02 PM   #5 (permalink)
View warlock's Photo Gallery
You should only need 5 basic wires. 1 one from the battery with a fuse
2 a good ground same size as your power
3 the remote from the radio.
4 left rca
5 right rca
Sounds like you don't know what the remote wire is. It should be ornge or blue on your radios harness. It sends a small 12 volt signal to the amp that turns it on and off.
94 Scepter 1MZ-FE
< TN Type [R]ice Club>RICERS UNITE!! Join Type R..latest faction of TN!!
.....http://www.toyotanation.com/forum/sh...d.php?t=105457
warlock is offline   Reply With Quote
Old 05-11-2009, 03:38 PM   #6 (permalink)
Biggg72's Avatar
i am car audio savy, i just didnt understand that chart that i found. when i do hook this up i am going to hook into the wires at the amp to go to the door speakers, so i would still need the diagram.
thanks i will make that call.
Old 05-11-2009, 03:42 PM   #7 (permalink)
Slaughter's Avatar
View Slaughter's Photo Gallery
What model is the amp?
Canadian Representative for Team Hamster
Slaughter is offline   Reply With Quote
Old 05-12-2009, 12:48 PM   #8 (permalink)
Now I'm confused. You need the diagrams to hook up 2 speakers? Not the amp its self?
94 Scepter 1MZ-FE
Old 05-12-2009, 02:52 PM   #9 (permalink)
Biggg72's Avatar
dont know the model right now, wifey has the car. i am hooking up subs, as well as another amp to the doors for more and better sound. instead of wiring new wires im going to use the output of the factory amp to go back to the doors. there are alot of wires hooked up and i wanna make sure i dont disconnect the wrong thing.
