Major System Upgrading Thread (56K Warning) - Page 3 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-23-2009, 02:37 PM   #31 (permalink)
LoudCamry's Avatar
Gameroom cash: $230427
View LoudCamry's Photo Gallery
I have to ground the pink wire on my kenwood which was for the ebrake wire so that the dvd player will work while in motion.
LoudCamry is offline   Reply With Quote
Old 06-23-2009, 08:40 PM   #32 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Originally Posted by Camricer View Post
I'm installing similar headunit to my friend car, this head unit one doesn't have AMP control wire. Can I hook the AMP control wire from the AMP together with the ACC wire (power supply of the headunit) ?
Some LOCs have built in remote wire. If you won't use a LOC, you can use the cigarette lighter or some other ACC switched wire.
2007 Camry 2.4L 5M
Old 06-24-2009, 04:25 AM   #33 (permalink)
Do not buy from
View Zviator's Photo Gallery
That's exactly what I plan to do. However my friend rather have the AMP turn on and off WITH the headunit. So back to my question, can I hook remote wire together with ACC power supply for headunit ?
Zviator is offline   Reply With Quote
Old 06-24-2009, 04:26 AM   #34 (permalink)
Do not buy from
Yes I do have a non used pink wire. Is grounding that wire the only option ? Can it be connected to another negative wire ?
Old 06-24-2009, 08:03 PM   #35 (permalink)
If you are using a stock HU or some weird HU that doesn't have a trigger wire, there really isn't an easy choice other than the two I mentioned above. I guess a third could be using a relay and a manual switch so he can turn on and off as he pleases.
2007 Camry 2.4L 5M
Old 08-21-2009, 04:39 AM   #36 (permalink)
Do not buy from
Ok, It's been 2 months and the system works perfectly fine except for that pink wire u mentioned. I actually was using my ipod most of the time so it didn't bother me much. But recently I digged up some nice classic CDs, so can someone clarify to me one last time what i need to do with the pink (safety) wire ?
Do I have hook it up to a negative wire or do I have to ground it to metal frame ?
Thanks,
Old 08-27-2009, 08:45 PM   #37 (permalink)
View Patty Robs's Photo Gallery
ground it.
Patty Robs is offline   Reply With Quote
