Blown Yet Not Blown Speaker - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-01-2009, 09:55 PM   #1 (permalink)
Gameroom cash: $300195
View cipher93's Photo Gallery
I've gone through something of a minor nightmare since installing a pair of new Rockford Fosgate Punch series speakers in my Corolla. The speakers are the newest Punch series They were fine for a weak, then the left/drivers side started to sound like it was blown. My first thought was it was touching the speaker deck cover; took it off and the issue remained. The surround is mounted correctly. So my next thought is it somehow was blown. But here is the catch; sometimes it doesn't, sometimes it won't. Feeling the very top/rubber part on the outside of the cone when ti is doing it, the cone just stops moving like it's loosing the signal.
The head unit is a 7 month old JVC KD-S25. Not their top product, not quite their cheapest. Now here is where it gets weird; if I take the face plate off, blow it off the contacts and spray a little contact cleaner it will work fine for a few days. I almost never take the face plate off and the contacts look fine. While I plan to test the connections to the car's wire harness because I'll have to pull out the head anyway if it needs to be fixed under warranty, I kinda doubt that is the issue.
The only other possibility I plan on checking is if when I went to put larger connectors on the wires on the car's speaker mount (the contacts on the speaker are bigger than normal) is that my solder joint wasn't good (unlikely; I have a lot of experience soldering electronics in guitars and instrument amps, which are a LOT higher voltage than a car sterep and never had a problem) but something I think I'll test.
Anyone else have any other ideas outside of what I've suggested (and switching the speakers around of course)? This has just driven me up a wall. I've ruled out a blown speaker because a blown speaker stays blown sounding in my experience...
cipher93 is offline   Reply With Quote
Old 06-01-2009, 10:50 PM   #2 (permalink)
on full afterburner
PhatRoyale's Avatar
Gameroom cash: $1191747
Maybe the speakers were defective?
A speaker out it's way out may go with periodic phases between functioning and not functioning properly. A common reason why speakers blow (and I've experienced this first hand myself) is from mis-matching speaker specs to the amplifiers output. This in turn can cause a speaker to be sent a signal that's "dirty" meaning it's either underpowered (which causes clipping and moments of distortion and extreme voltage) or overpowered them excessively which can lead to the voice coils being destroyed.
Old 06-02-2009, 12:12 AM   #3 (permalink)
Speakers are rated for 60watts RMS and 120watts Max The heads is 20 watts RMs into 4 channels, 50 Max into 4 channels. Which I have no clue what that means LOL, and nothing I've found is real clear. All of this is at 4ohms too so I know it isn't a mismatch there. Could it have something to do with my front speakers being broken?
Old 06-05-2009, 12:21 PM   #4 (permalink)
I swapped the problematic one to the other side of the car and vice versa. Still doing it to the same speaker, so it's blown... at least I can exchange it, hopefully for something else.
