aftermarket amp for subs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-11-2009, 11:59 PM   #1 (permalink)
Biggg72's Avatar
View Biggg72's Photo Gallery
ive read more about what subs what amps, how this and that. where is the easiest spot to run the power wire thru on 07 camry?
also i read numerous times there are no rca's on the stock radio, but it wasnt specific, does this include the jbl as well?
i know everything else for my install, i just dont wanna tear into wifeys camry like i do my car and truck.
Biggg72 is offline   Reply With Quote
Old 06-12-2009, 11:42 PM   #2 (permalink)
Biggg72's Avatar
nobody.........................anybody............ ..........................somebody?
Old 06-12-2009, 11:48 PM   #3 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $283505
View MrSo0h0o's Photo Gallery
easiest spot to run the power wire is through the firewall near the steering column
no RCA inputs at all
MrSo0h0o is offline   Reply With Quote
Old 06-12-2009, 11:50 PM   #4 (permalink)
touringcamry's Avatar
Gameroom cash: $510625
Have you even tried looking for somewhere to run the wire? Just run it through one of the rubber plugs in the firewall. I ran mine through somewhere behind the glovebox. I know I've posted this more than once, but searching is too much to ask I suppose.
As for your second question, there are none because using them would be an unnecessary complication to their stereo system.
2007 Camry 2.4L 5M
Old 06-13-2009, 07:16 PM   #5 (permalink)
Biggg72's Avatar
i appreciate it, thanks
look here dude, just like any other forum they are filled with a bunch of uneccesary garbage in any thread, i did search, but im not gonna spend my whole time reading thru alot of nonesense to find one thing. i apologize i took 30 seconds out of your life to type what you did, if i can make it up to you please feel free and let me know. i also apologize for not having a camry as my dd, my wife drives this car and its hard enough to get time to wash it let alone pop the hood and do what i wish to do. although you have 5 g's+ on post, im sure you started the same way.
Old 06-15-2009, 03:05 AM   #6 (permalink)
To be honest, I didn't search the forums either when I went to install my amp. I just popped the hood and found where to run the wire in about a minute since that rubber grommet is fairly obvious.
2007 Camry 2.4L 5M
Old 06-19-2009, 09:12 AM   #7 (permalink)
Biggg72's Avatar
i will be re using some wire, curious to know if you remember how many feet you used, i dont wanna have to do it twice.
Old 06-19-2009, 09:46 AM   #8 (permalink)
MrSo0h0o's Avatar
IIRC, i used 15'-20', maybe a little more for some slack and depending on where your amps are mounted
Old 06-19-2009, 12:33 PM   #9 (permalink)
Biggg72's Avatar
thanks im right at 19 so i may be right on.
